RouterIssues4me
Jan 05, 2021Aspirant
XR500 and EX7700 Extender - No Devices in Device Manager in IOS Nighthawk App
I've been using the Nighhawk app for months to block devices nightly and unblock in the AM. After adding the EX7700 the device manager no longer works on the app, but I can see the devices in th...
Netduma-Fraser
Jan 05, 2021NetDuma Partner
TimChang could you look at this issue please?
I would recommend you upgrade to the beta firmware, you can then use the DumaOS app that we have developed and use the actual Device Manager there.
- RouterIssues4meJan 05, 2021Aspirant
It looks like some issues with the current version of 3.0 for the 500 so I'm not sure that will be a good fix at the moment.
- Netduma-FraserJan 06, 2021NetDuma PartnerIt's a beta so there will be issues for some users but not all with post or have issues, it may work fine for you, you could always downgrade if needed.
