bigc1955
Apr 06, 2020Aspirant
XR500 and hardware firewall
Just a quick question.... Would I gain anything be installing a hardware firewall (i.e., Bitdefender Box 2) into my network setup? This would be that I would have to put my XR500 into bridge/AP ...
Netduma-Fraser
Apr 07, 2020NetDuma Partner
All routers have their own Firewall including the XR500 and if you're running the latest firmware then any known vulnerabilities have been fixed. I don't think it would be necessary to do something like that - if you were concerned then make sure you do not use the DMZ, disable remote management if it's been enabled and ensure your WiFi password is long and alphanumeric. Could also consider disabling respond to internet ping in WAN Settings as well. That's just my opinion but if you're concerned then do what makes you feel more at ease.
