r1cketier
Sep 12, 2021Follower
XR500 AND IINET
Hello, I've just moved to a house with FTTP. I had the XR500 working at my previous address (HFC connection) and have tried with no luck to set it up at the new house. I have enabled VLAN tag to...
Netduma-Fraser
Sep 12, 2021NetDuma Partner
For VLAN remove the rule you've made and edit the existing internet rule and change it to 2, see if that works. Also set PPPoE to always connect.
