Zachary-sama
Sep 27, 2020Guide
XR500 and mesh extender
Hey, i bought the nighthawk xr500 gaming router with mesh extender a while ago, i followed their setup guide on youtube. Almost everything works fine, the problem is when i use my ps4... i c...
- Sep 27, 2020In WAN Settings switch NAT to Open and toggle SIP ALG, see if that helps.
Zachary-sama
Sep 27, 2020Guide
the issues occur when i'm not using the geo filter as well though
Netduma-Fraser
Sep 27, 2020NetDuma Partner
How are you connecting the PS4? Is it through WiFi through the extender or via ethernet?
- Zachary-samaSep 27, 2020Guide
i have an ethernet running from my normal router to the rx500, wich then has an ethernet running to my ps4, i can't hook up the netduma without an ethernet from my normal router
- Netduma-FraserSep 27, 2020NetDuma PartnerSo if you completely disable the Geo-Filter so don't have your PS4 added at all you still have the same issues?
yes, i still have the same issue with the geo filter disabled
