Zachary-sama
Sep 27, 2020Guide
XR500 and mesh extender
Hey, i bought the nighthawk xr500 gaming router with mesh extender a while ago, i followed their setup guide on youtube. Almost everything works fine, the problem is when i use my ps4... i c...
- Sep 27, 2020In WAN Settings switch NAT to Open and toggle SIP ALG, see if that helps.
Zachary-sama
Sep 27, 2020Guide
my nat type is nat type 2 moderate, i can connect to people in game no problem, but not with voice chat in parties or to servers, it will give me infinite loading screens
Netduma-Fraser
Sep 27, 2020NetDuma Partner
- Zachary-samaSep 27, 2020Guide
this does seem to fix the problem, but isn't having an open nat type a bad thing? i already do really appreciate this fix though
- Netduma-FraserSep 27, 2020NetDuma PartnerNo you want an open NAT because that allows you to connect properly to applications/services. You're still protected by the router firewall.
oh ok, anyway it seems to be working fine for now, so thank you so much, i didn't test everything yet but i can already connect with voice chat and hear people again haha, if problems do occur again i'll be asking for your help again, once again i really do appreciate it!
- Zachary-samaSep 30, 2020Guide
Udate:
After some more testing i can confirm now that,
Party chat works fine
All games work fine as well
in short your fix really helped me out, i appreciate it!
