BraveHeart95's avatar
BraveHeart95
Xr500 and mesh network
Hello
I have Netgear Xr500 for about 2 years and i recently bought mesh network system (linksys velop) is there a way that i can connect the main node with cable (modem-xr500-node1)
So i can basically use the xr 500 for devices that are connected by cable with all features like geo-filter and qos and use the velop for wireless ?
    • blw4f's avatar
      blw4f
      Tutor
      I've decided to try and make this work as well. I've got my velop in 'Bridge Mode'... which from what I can tell, is their version of AP mode.
      I can only see one issue at this point. The mesh seems to be working but I'm seeing another 'open' network by the same name. I don't understand what is causing that. Does anyone have any ideas?
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Double check the XR WiFi settings, do you see that network there? This might be one for linksys support.
