bsilverthorn
Dec 12, 2018Apprentice
XR500 and PI Hole configuration
I am looking for a way to use dnsmasq with the XR500. Or some way to have the pi hole software be able to report back what machines are actually doing the dns lookups. In most routers I have an optio...
Biggus42
May 13, 2019Tutor
I've had the same issue - it is as if the XR500 "Use These DNS Servers" option doesn't work.
No matter what you put in there, it just pushes down the values it gathers from your ISP; you cannot override them.
Is this something that is in the channel to get fixed?
Thank you!
Netduma-Fraser
May 14, 2019NetDuma Partner
Biggus, what happens after you set the DNS and apply? When it reloads the page has it switched back to dynamic or is it still on 'Use these...' but doing a DNS test it shows the ISP DNS?
- Biggus42May 14, 2019Tutor
The router appears to be configured properly, but what it delivers is the ISPs values to the devices.
- Netduma-FraserMay 14, 2019NetDuma PartnerAre you using your ISP hub in router mode? If so change to modem mode, does it appear to work correctly then?
