clarky1326
Feb 09, 2019Aspirant
XR500 and S8000 Setup
For ideal use... Have all wired devices plugged into S8000 switch and also use another router in AP mode for WiFi. My question is will the qos in the xr500 and s8000 conflict with each other or ...
Netduma-Fraser
Feb 10, 2019NetDuma Partner
I just responded to your other post about this but I'll paste it here too:
Yes they probably would. I would highly suggest you disable the QoS features on the switch. The XR500 QoS is absolutely capable of ensuring your network doesn't suffer any local congestion. You would have a much better experience relying on the state of the art QoS on the XR500.
- B1ggSh00t3rFeb 10, 2019Apprentice
As far as I know, you cannot "disable" QoS on the S8000. I've checked the settings and wasn't able to find an option to disable QoS. I've have QoS enabled on the XR500 and S8000 and haven't noticed any issues w/ devices connected (wired / wireless) on my home network.
- clarky1326Feb 10, 2019AspirantOnly way I can think of is change the preset mode into standard and turn off IGMP snooping, put each port to high priority with no limits for in rate and out rate.
- Netduma-FraserFeb 10, 2019NetDuma PartnerThat sounds like it would do the job or you could follow the above advice, if you get any issues then try that
