bigc1955
Mar 26, 2020Aspirant
XR500 and VLANs
I'm looking to get an XR500 and replace my pfSense box. I have a VLAN set on the pfSense box for my IOT devices. Will I be able to do the same type setup with the XR500? Thanks.
Netduma-Fraser
Mar 26, 2020NetDuma Partner
You're able to enable VLAN by bridge group or by VLAN tag group so it should be possible to do that yes.
