Klawtrax
Mar 14, 2023Aspirant
XR500 and X4S on the same network. Need help please
Hello All Right now I have an X4s doing the work of both the modem and router. I have also an XR500 on the shelf that I can use. What I want to do: My brother and his family live upstairs, me and ...
Mar 15, 2023Guru - Experienced User
Whats the X4S? C7800 or R7800?
- KlawtraxMar 15, 2023AspirantSorry about that I wrote down the wrong model number it’s a Netgear C 7800 modem router combo.
- FURRYe38Mar 15, 2023Guru - Experienced User
Try putting the C7800 in modem only mode:
https://kb.netgear.com/27191/How-to-set-the-cable-modem-router-to-be-on-modem-only
Then you can use the XR as the main router.
- KlawtraxMar 15, 2023AspirantI’m looking to make two separate wireless networks
With both networks having a full featured router
