Klawtrax
Mar 14, 2023Aspirant
XR500 and X4S on the same network. Need help please
Hello All Right now I have an X4s doing the work of both the modem and router. I have also an XR500 on the shelf that I can use. What I want to do: My brother and his family live upstairs, me and ...
Mar 15, 2023Guru - Experienced User
Whats the X4S? C7800 or R7800?
Klawtrax
Mar 15, 2023Aspirant
Sorry about that I wrote down the wrong model number it’s a Netgear C 7800 modem router combo.
- FURRYe38Mar 15, 2023Guru - Experienced User
Try putting the C7800 in modem only mode:
https://kb.netgear.com/27191/How-to-set-the-cable-modem-router-to-be-on-modem-only
Then you can use the XR as the main router.
- KlawtraxMar 15, 2023AspirantI’m looking to make two separate wireless networks
With both networks having a full featured router- FURRYe38Mar 15, 2023Guru - Experienced User
Then run the C7800 in gateway mode and use the modems DMZ for the XR500.
If you run both wifi, be sure to use manual channels far apart on each unit.
