Rab1967
May 06, 2021Tutor
XR500 and Xbox Console - How do I get Geo-filter to connect me to USA Host when I am in Europe?
I bought the XR500 becasue of the Geo-filter capabilities, but I thought it would allow me to selectively adjust where I wish to connect to gaming servers, even if in another country. However, I ...
Netduma-Fraser
May 07, 2021NetDuma Partner
You will need to set Ping Assist to 0, that is how you force servers in another country, otherwise it may get you games closer to home.
- Rab1967May 08, 2021TutorThx, I will try that.
- Rab1967May 09, 2021Tutor
Ping Assist at 0
It seems that in my case setting Ping Assist to zero, does not work. My connection are still all initiating in Europe.
- Netduma-FraserMay 09, 2021NetDuma PartnerI can't see the picture as it needs to be moderated, can you attach it directly please?
