Zeishaan
Aug 11, 2021Aspirant
Xr500 antenna port loose
so my antenna port is loose so does anyone know how to fix it ??
Aug 11, 2021Guru - Experienced User
Sugru?
If the antenna still works, a little sugru might be a decent fix.
Or what part is loose? the connector?
- ZeishaanAug 12, 2021Aspirant
yes the connector the gold part is loose shall i use some super glue on it
- plemansAug 12, 2021Guru - Experienced User
so where it actually screws to the router?
I'd probably not super glue it. Does it tighten at all?
I don't have that router (so not familar with those exact antenna's).
Plus you posted in the general router forum and not the pro router forum.
They might know more about those specific antenna's.
its the part you screw antenna on to, so the gold atenna part is loose
