JConn1973
Aug 07, 2021Follower
XR500 antennas lookin for amplified antennas
I have an XR500 and want to get amplified antennas for it. The 4 antennas - are there 2 for 2.4 and 2 for 5GHz? Does it matter which antennas I get as long as they fit and the are 2.4/5 comp...
Netduma-Fraser
Aug 08, 2021NetDuma Partner
The antennae are already amplified and are high performance, there is no guarantee whatever antennae you get that they will improve your range - there are no specifics on what type of antennae they are
