Rosse
Nov 16, 2018Aspirant
XR500 antennas
Hi all. Just bought a XR500, which has 4 antennas. 2 on the back, both marked “1”, and antenna marked “2” on the left and “3” on the right. The number ”3” antenna does not fit into the right slot (...
Netduma-Fraser
Nov 16, 2018NetDuma Partner
The numbers should match up so odd that they don't. However as far as I am aware they are all the same length/have the same function so in theory it shouldn't matter too much which one they're connected to.
Rosse
Thanks a lot for the quick reply.
I agree. The external dimensions are the same of all 4 antennas.
But if it is just a matter of design, or actually the antenna inside the plastic protection on the antenna, that’s what I’m most curious about...
- Netduma-FraserNov 16, 2018NetDuma PartnerI think the antennas were just misnamed on your router for some reason, won't affect performance in any way
