Rosse
Nov 16, 2018Aspirant
XR500 antennas
Hi all. Just bought a XR500, which has 4 antennas. 2 on the back, both marked “1”, and antenna marked “2” on the left and “3” on the right. The number ”3” antenna does not fit into the right slot (...
Rosse
Thanks a lot for the quick reply.
I agree. The external dimensions are the same of all 4 antennas.
But if it is just a matter of design, or actually the antenna inside the plastic protection on the antenna, that’s what I’m most curious about...
Netduma-Fraser
Nov 16, 2018NetDuma Partner
I think the antennas were just misnamed on your router for some reason, won't affect performance in any way
