Xr500
Feb 14, 2019Apprentice
XR500 Anti-Bufferbloat BUG
Anti-Bufferbloat When operating all settings. Error prompt:
RPC error 'ERROR_NOENT': Rule not found in chain
Uptime : 36 days
Firmware: XR500 V2.3.2.40
Happy New Year!
Here I am ...
Netduma_Jack
Feb 19, 2019NetDuma Partner
That can sometimes happen when moving from an old firmware version to a new one. You can clear the error and it will work, but if it's bugging you, then a factory reset should solve this: https://kb.netgear.com/000053098/How-do-I-perform-a-factory-reset-on-my-Nighthawk-Pro-Gaming-router
Netduma_Jack
Equally - you might be able to just reboot the router to clear the problem (no need for a full factory reset).
- Xr500Jul 03, 2019Apprentice
Hi, Netduma_Jack.
XR500 when to update the firmware?
I am thinking about selling it. really a forgotten router
- Netduma_AlexJul 03, 2019NetDuma Partner
Updates are definitely coming!
Thank you. I'm looking forward to it.
- FURRYe38Jul 03, 2019Guru - Experienced User
Try a downgrade of FW to v32 and see.
thank you. i'll try
