Jefferzz93
Jul 20, 2020Guide
XR500 anti bufferbloat not engaging on pc
Hey guys trying to figure out antibufferbloat, so I have less than favourable internet. My upload and download are about the same at 20mbps. I usually run my anti buffer at 15 down and 8 up and have i...
Netduma-Fraser
Jul 21, 2020NetDuma Partner
Can you see the PC in the Device Manager? Have you got the PC added to Traffic Prioritization or is the high priority light active when you're doing a speed test?
Jefferzz93
Jul 21, 2020Guide
Yes to all of your questions
- Netduma-FraserJul 21, 2020NetDuma PartnerThat will be why then as Traffic Prioritization supersedes QoS so remove any manual rules you've added to Traffic Prio and it should adhere to the Anti-BB percentages.
- Jefferzz93Jul 21, 2020GuideI haven’t added any manual rules to pc for prio, or are you saying just remove from traffic prio completely for pc ? Will that affect gameplay when network is congested ?
- Netduma-FraserJul 21, 2020NetDuma PartnerCould you provide a screenshot of your entire QoS page please and then I can best advise.
