stran9er
Jan 18, 2023Aspirant
XR500 as AP mode dropped all Wifi connections
I have noticed for a while that my Nighthawk XR500 was only giving me a fraction (120 mbps) of my full internet speed (950+ mbps). I had no use for QoS, so I decided to switch to AP mode. Now, m...
Jan 18, 2023Guru - Experienced User
What is the Mfr and model# of the host router the NG router is connected too?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended. \
Is the XR the only item broadcasting WIFI. Do you have the main host routers wifi enabled?
How do you have both Basic tab/wireless and Advanced tab/wireless settings configured?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
stran9er
The update found no new version of the firmware. I cannot connect back to the router interface to find out exactly.
The NG is connected via CAT6 to a Hitron EN2251, the standard used by Spectrum.
The XR is the only WIFI broadcast in my home.
I cannot see the settings as I am no longer able to connect to routerlogin.net or via Nighthawk App. I do know the channels were set to Auto on 5Ghz and 11 on the 2.4Ghz channel.
The XR is not taking a factory reset, I have pressed the reset button and held it for 30 seconds and it just goes back to the current settings.
- FURRYe38Jan 18, 2023Guru - Experienced User
Had this worked before or did you just configure AP mode on the XR router?
FYI, AP mode will not work on the XR router as the host ISP service device is a modem only and no router built in here. The XR when in AP mode needs a ROUTER to service an IP address and internet traffic to the XR router.
To get back to router mode, factory reset the XR router by pressing the reset button for 10 seconds then release. Then walk thru the setup wizard at 192.168.1.1. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
