stran9er
Jan 18, 2023Aspirant
XR500 as AP mode dropped all Wifi connections
I have noticed for a while that my Nighthawk XR500 was only giving me a fraction (120 mbps) of my full internet speed (950+ mbps). I had no use for QoS, so I decided to switch to AP mode. Now, m...
stran9er
The update found no new version of the firmware. I cannot connect back to the router interface to find out exactly.
The NG is connected via CAT6 to a Hitron EN2251, the standard used by Spectrum.
The XR is the only WIFI broadcast in my home.
I cannot see the settings as I am no longer able to connect to routerlogin.net or via Nighthawk App. I do know the channels were set to Auto on 5Ghz and 11 on the 2.4Ghz channel.
The XR is not taking a factory reset, I have pressed the reset button and held it for 30 seconds and it just goes back to the current settings.
Jan 18, 2023Guru - Experienced User
Had this worked before or did you just configure AP mode on the XR router?
FYI, AP mode will not work on the XR router as the host ISP service device is a modem only and no router built in here. The XR when in AP mode needs a ROUTER to service an IP address and internet traffic to the XR router.
To get back to router mode, factory reset the XR router by pressing the reset button for 10 seconds then release. Then walk thru the setup wizard at 192.168.1.1. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
