Raf1212
Jun 08, 2020Apprentice
xr500 beta DUMAOS 3.0
hello everyone, I have a question where the beta version 3.0, the big announcement was 02.06, still nothing, a week passed, many people are waiting for it because xr500 is not working well, it is ver...
z0nk
Jun 10, 2020Star
Indeed, pay 300€ for router that has really good hardware that cannot be fully used makes me angry. There are security gaps (official firmware still base on openwrt 12.10, I hope that new beta will base at least of 19.07 and will have new ath10k driver). Also limiting VPN providers into 2 is misconception. I'm clean openwrt user for about 10 years and one of driver for me to purchase device was that it was based on openwrt and I will be able to do something more with it.
I also sign up for beta to help resolve issues that are crucial for me.
- Raf1212Jun 10, 2020Apprentice
z0nk you're right in your statement, I'm not as advanced in knowledge as you are, but it sounds good
- Netduma-FraserJun 10, 2020NetDuma Partnerz0nk you can use any VPN you like, you will just need to input their OpenVPN configs.
- z0nkJun 10, 2020Star
yes, it still 1 config only for OpenVPN . No option to prepare zip file with proper structure that allows to select country for provider (like buildin one). Also no option to have PPTP vpn, strongswan and setup server/client for wireguard. there are much more things expect vpn like missing 6to4 or 6in4 IPv6 provider, autobackup scripts, timemachine support, no bonding,load balacing etc... Also I cannot set network name with unicode chars by DumaOS limitation. when login via telnet and set like below it's working fine, until reboot, after that old settings are restored.
# uci set wireless.@wifi-iface[0].ssid="$(echo -e 'DumaOS is the best \xf0\x9f\x98\x8d')" # uci set wireless.@wifi-iface[1].ssid="$(echo -e '5G DumaOS is the best \xf0\x9f\x98\x8d')" # uci commit # wifi
I can also switch to official openwrt branch, howver then I lost my warranty and mostly important some firmware is property of netgear and deliver some hardware functions that opensource driver doesn't provide/they are unstable.
