Raf1212
Jun 08, 2020Apprentice
xr500 beta DUMAOS 3.0
hello everyone, I have a question where the beta version 3.0, the big announcement was 02.06, still nothing, a week passed, many people are waiting for it because xr500 is not working well, it is ver...
Raf1212
Jun 10, 2020Apprentice
z0nk you're right in your statement, I'm not as advanced in knowledge as you are, but it sounds good
Netduma-Fraser
Jun 10, 2020NetDuma Partner
z0nk you can use any VPN you like, you will just need to input their OpenVPN configs.
- z0nkJun 10, 2020Star
yes, it still 1 config only for OpenVPN . No option to prepare zip file with proper structure that allows to select country for provider (like buildin one). Also no option to have PPTP vpn, strongswan and setup server/client for wireguard. there are much more things expect vpn like missing 6to4 or 6in4 IPv6 provider, autobackup scripts, timemachine support, no bonding,load balacing etc... Also I cannot set network name with unicode chars by DumaOS limitation. when login via telnet and set like below it's working fine, until reboot, after that old settings are restored.
# uci set wireless.@wifi-iface[0].ssid="$(echo -e 'DumaOS is the best \xf0\x9f\x98\x8d')" # uci set wireless.@wifi-iface[1].ssid="$(echo -e '5G DumaOS is the best \xf0\x9f\x98\x8d')" # uci commit # wifi
I can also switch to official openwrt branch, howver then I lost my warranty and mostly important some firmware is property of netgear and deliver some hardware functions that opensource driver doesn't provide/they are unstable.
- Netduma-FraserJun 10, 2020NetDuma PartnerThe idea behind the router is to be easy to use and to have people start interacting with routers more, if you want really fine control over things like that then it may come in the future but not right now.
I agree that it should be easy to use by games,
Please understand that, if you buy sports car to drive on track, you don't expect that it will have set speed limiter into 100mph ( you can remove it but then you loose waranty).
When we buy premium router, we don't expect to be limited by web frontend, we can change firmware to 3rd party, but then we loose warranty.
What would you do with such sport car after purchse and found it out? Is there possiblity to support powerusers without loose warranty on device?
