anovelli2002
Oct 29, 2021Aspirant
XR500 beta
i recently installed the beta version for the xr500. it is still losing wifi fir a min at a time. I am definetely unhappy with the amount spent for the wifi to be going out as often as it has been....
Jan 11, 2022Guru - Experienced User
Factory reset the router and setup from scratch.
Change the LAN IP address pool range to 192.168.1.100 to .200. Apply the change and the router should reboot itself.
For beta FW and experiences be sure to post over tin the beta forum for the XR series:
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/bd-p/en-home-beta-npg-duma
