Mike40
Dec 08, 2024Luminary
XR500 Black Ops 6 no ping on PC
 Just like the subject says.  There are no pings when playing BO6 on PC.  There isn't anything for BO6 in the Ping Heatmap either.  This has been going on since the day the game launched over a month ...
- Dec 08, 2024The beta is here: https://forum.netduma.com/topic/51611-new-xr500-beta-firmware-33535/
Try this:
Quit the application/game/client completely
Remove device from the Geo-Filter
Give PC PlayStation Device Type in the Device Manager
Resync from the Geo-Filter Map menu
Re-add the device to the Geo-Filter with the manual option
Set up the Geo-Filter how you like
Wait 2 minutes
Boot up application/game/client
Then see if it works.
Dec 08, 2024Guru - Experienced User
Is the game working?
Probably something that may need to be added. If thats even possible.
Tried the NetDuma beta?
Mike40
The game "works" but it doesn't work well since I can't use the Geo-Filter.  I live by Chicago and the server is always trash.  That is why I use the Geo-Filter so I can connect to either Ohio or Georgia.  Playing MP is almost unplayable so I just play Zombies since having little glitches doesn't really mess with my game.
How do I get the beta?  I would be willing to try it so that I can play MP again.
- Netduma-FraserDec 08, 2024NetDuma PartnerThe beta is here: https://forum.netduma.com/topic/51611-new-xr500-beta-firmware-33535/
Try this:
Wait 2 minutes
Then see if it works.- Mike40Dec 08, 2024Luminary
I did everything you said and now BO6 does show up in Ping Heatmap but I still get no ping. This is a SS from while I was in a match. According to the Geo-Filter, I wasn't even connected to anything.
- Netduma-FraserDec 08, 2024NetDuma PartnerCan you attach it directly please? I can't see it otherwise until it's been moderated
