Mike40
Dec 08, 2024Luminary
XR500 Black Ops 6 no ping on PC
Just like the subject says. There are no pings when playing BO6 on PC. There isn't anything for BO6 in the Ping Heatmap either. This has been going on since the day the game launched over a month ...
- Dec 08, 2024The beta is here: https://forum.netduma.com/topic/51611-new-xr500-beta-firmware-33535/
Try this:
Quit the application/game/client completely
Remove device from the Geo-Filter
Give PC PlayStation Device Type in the Device Manager
Resync from the Geo-Filter Map menu
Re-add the device to the Geo-Filter with the manual option
Set up the Geo-Filter how you like
Wait 2 minutes
Boot up application/game/client
Then see if it works.
Mike40
I did everything you said and now BO6 does show up in Ping Heatmap but I still get no ping. This is a SS from while I was in a match. According to the Geo-Filter, I wasn't even connected to anything.
Netduma-Fraser
Dec 08, 2024NetDuma Partner
Can you attach it directly please? I can't see it otherwise until it's been moderated
- Mike40Dec 08, 2024Luminary
The one I attached is with my PC in console. The SS you couldn't see I had nothing in Geo-Filter but still the same thing. There is no ping to any server/player while I'm in the game.
- Netduma-FraserDec 08, 2024NetDuma PartnerThe first screenshot (it's been moderated now) you hadn't added a device so nothing will appear on the map. The second one you've switched to polygon mode but not drawn any zones - draw some areas or switch polygon off and then it should work.
I've tried turning the Geo-Filter on/off nothing pings.
I've made a polygon still nothing. I turned off polygon still nothing.It seems like no matter what I do, I can not get anything to ping.
The reason I do this is so that when I have a glitchy match I can block the server/person so I don't connect to them again.
I can't see who/what I'm connecting to so 9 out of 10 matches are crap.
