Chrch
May 17, 2021Aspirant
XR500 Blinking Red Internet LED
Router has been working fine. Get home and Internet LED is blinking red and lost router connection to Internet. Have tried cycling the modem, factory reset, nothing has worked. Internet works when wir...
- May 18, 2021
what actual modem do you have?
Try this.
Power off both the modem and the router. disconnect everything from both (even coax from modem).
Wait 2 minutes.
connect coax back to the modem.
power the modem on and wait 2 minutes.
connect the modem to the router.
power the router on and wait 2 minutes.
Try it then.
Chrch
May 18, 2021Aspirant
Netduma-Fraser wrote:
What firmware version are you on currently?
I'm on V2.3.2.114 now. I was on 2.3.2.56 when the issue started. Do you recommend staying on the latest version?
Netduma-Fraser
May 18, 2021NetDuma Partner
Glad to hear it's all working now! Yes I would recommend staying on the latest version
