TokeZen
Feb 06, 2019Aspirant
XR500 blocking my Upload tests?
Hey guys,
I got this router few days ago and had a go at it. Loving it so far, fixed most of my networking issues I had with previous router I used.
However, I couldnt test my upload speed at spe...
- Feb 07, 2019
If other devices work and this one particular PC doesn't, I would try different browser, disable all security software and browser plug-ins temporarily. Ensure your network adapter is set for Auto Obtain IP addressing.
Install speedtest.net testing app instead of using a browser.
TokeZen
Feb 07, 2019Aspirant
So I speedtest.net on another PC and 2 different phones and it works there. Thus it became clear that my PC is at fault here, any ideas what steps I could take to identify the issue? Just to emphasize, if I turn off QoS, speedtest works on my pc too, like others. Once it's on it's a no go for my PC
- FURRYe38Feb 07, 2019Guru - Experienced User
- Netduma_JackFeb 07, 2019NetDuma Partner
Good job in isolating where the fault is. Now we know it's the PC, it's probably do with firewall or security software on your computer. It's seeing you're about to upload a shed load of data and is stopping it to be cautious.
Try Furry's suggestions and let us know if you manage to get to the bottom of it.
- TokeZenFeb 07, 2019Aspirant
I just tried using Opera and it worked just fine. Turns out Firefox was causing the issue, thanks a lot!
Im also in process of figuring out another issue, perhaps you can help?
After my PC runs for a few hours my download speed gets throttled to 6mbps when normally i get around 900mbps -1gbps.
I tried different browsers, restarting modem & router - no results to report.
This is also just my PC's issue, no other device on the network seem to experience this
- Netduma_JackFeb 08, 2019NetDuma Partner
That sounds like it might be overheating, or that the CPU is maxed out for some reason. Putting a lot of bandwidth through anything uses computer power.
Easiest way to check would be to open up Task Manager when the speeds are very slow. In the Processes tab, see if the CPU is maxed out. If it is, try and see what's using it all.
If it's not, then is the PC especially hot?
