TokeZen's avatar
TokeZen
XR500 blocking my Upload tests?
Hey guys, I got this router few days ago and had a go at it. Loving it so far, fixed most of my networking issues I had with previous router I used. However, I couldnt test my upload speed at spe...
  • FURRYe38's avatar
    If other devices work and this one particular PC doesn't, I would try different browser, disable all security software and browser plug-ins temporarily. Ensure your network adapter is set for Auto Obtain IP addressing.
    Install speedtest.net testing app instead of using a browser.
