crookedfingaz
Jan 14, 2021Aspirant
XR500 blocking websites
this is my first time every using an advanced router before. Is it normal for these things to randomly block websites without permission? If so, how do I stop that from happening, and unblock the web...
crookedfingaz
So I was going to transfer internet companies, and one of the companies wanted me to fill out my current modems MAC address. I’m assuming that the router saw this as sensitive information and immediately pulled the plug on that site. I was using my laptop over wifi while it happened. All other websites worked. I tried loading the site on my phone (connected to wifi) same issue. Turned off my phones wifi, reloaded the site, and it was working fine.
The router is the xr500 pro gaming router
The modem is a hitron cda3-20
I don’t use wired for anything, all wifi here (which is why I got this router)
Netduma-Fraser
Jan 14, 2021NetDuma Partner
If it was one specific site then it may be just what you mentioned or that the ISP blocked it, I'd suggest plugging directly into the modem and seeing if you see the same issue. If you just need to connect to that site the one time then if it is an issue on the modem access it using the phone data as you did there and complete it then it shouldn't present as a problem in future.
