UrbanLegend
Aug 06, 2018Star
XR500 blocks Netflix, Hulu and Prime Video as a DoS Attack
First, a bit of a complex setup description.
CM700 (32x8) DOCSIS 3.0 Cable Modem connected to Comcast 250 connection
XR500 Router - Latest firmware - 1 Xbox One X connected directly with Ethern...
- Aug 08, 2018Did it go through the setup wizard? I've sent you a PM to try with a newer firmware
Netduma-Fraser
Aug 06, 2018NetDuma Partner
Disable the Geo-Filter, does it work then?
- UrbanLegendAug 06, 2018Star
I don't have any devices added to GeoFilter and not set the radius. Where would I disable the Geo Filter outright? Do I have to disable the r-app?
- Netduma-FraserAug 06, 2018NetDuma PartnerThats fine then you don't have it enabled. Delete any custom rules in Traffic Prioritization and disable DumaOS Classified Games and see if that resolves it
I don't believe I have any of those set. The only thing I did after plugging in the router was upgrade firmware, set the SSID and passwords for 2.4GHz and 5GHz channels. All other settings are default (Guest Wifi is off etc).
