UrbanLegend
Aug 06, 2018Star
XR500 blocks Netflix, Hulu and Prime Video as a DoS Attack
First, a bit of a complex setup description.
CM700 (32x8) DOCSIS 3.0 Cable Modem connected to Comcast 250 connection
XR500 Router - Latest firmware - 1 Xbox One X connected directly with Ethern...
- Aug 08, 2018Did it go through the setup wizard? I've sent you a PM to try with a newer firmware
UrbanLegend
Aug 06, 2018Star
I don't have any devices added to GeoFilter and not set the radius. Where would I disable the Geo Filter outright? Do I have to disable the r-app?
Netduma-Fraser
Aug 06, 2018NetDuma Partner
Thats fine then you don't have it enabled. Delete any custom rules in Traffic Prioritization and disable DumaOS Classified Games and see if that resolves it
- UrbanLegendAug 06, 2018Star
I don't believe I have any of those set. The only thing I did after plugging in the router was upgrade firmware, set the SSID and passwords for 2.4GHz and 5GHz channels. All other settings are default (Guest Wifi is off etc).
- Netduma-FraserAug 06, 2018NetDuma PartnerDumaOS Classified Games is enabled by default. Also change DNS, thats most often the cause when specific services are blocked.
Thanks, will give it a try tonight and let you know what I find.
