UrbanLegend
Aug 06, 2018Star
XR500 blocks Netflix, Hulu and Prime Video as a DoS Attack
First, a bit of a complex setup description.
CM700 (32x8) DOCSIS 3.0 Cable Modem connected to Comcast 250 connection
XR500 Router - Latest firmware - 1 Xbox One X connected directly with Ethern...
- Aug 08, 2018Did it go through the setup wizard? I've sent you a PM to try with a newer firmware
UrbanLegend
Aug 08, 2018Star
Regarding the Android phone part of the issue. That looks like it is known and mentioned in the other thread - https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/XR500-drops-internet/m-p/1572449/highlight/true#M1686
Netduma-Fraser
Aug 08, 2018NetDuma Partner
Fresh off a factory reset does the issue still occur? Disable QoS completely from Anti-Bufferbloats settings and see if that resolves it. If not we can look into more debug info.
- UrbanLegendAug 08, 2018Star
I did factory reset but with latest available firmware through the Dashboard. Not sure how to roll back the firmware or even if that is possible.
Same issues with the factory reset using the button on the back of the router.
- Netduma-FraserAug 08, 2018NetDuma PartnerDid it go through the setup wizard? I've sent you a PM to try with a newer firmware
It had gone through the Setup Wizard. I downloaded and installed the firmware you DM'd me and it seems to have resolved the issues on Android and Xbox One consoles in terms of multiple machines streaming. I'll let it run for a couple of days and let you know if I run into any issues as I try things out with different machines.
Just wanted to give you a heads up that it looks good so far.
- Netduma-FraserAug 09, 2018NetDuma PartnerGreat to hear that, thanks for the update. Fingers crossed it continues.
- UrbanLegendAug 13, 2018Star
So I ran over the weekend on the new firmware and the router ran like a dream. No drops, no lost connections, no streaming issues on any console or Android device.
Thanks
