UrbanLegend
Aug 06, 2018Star
XR500 blocks Netflix, Hulu and Prime Video as a DoS Attack
First, a bit of a complex setup description.
CM700 (32x8) DOCSIS 3.0 Cable Modem connected to Comcast 250 connection
XR500 Router - Latest firmware - 1 Xbox One X connected directly with Ethern...
- Aug 08, 2018Did it go through the setup wizard? I've sent you a PM to try with a newer firmware
UrbanLegend
Aug 08, 2018Star
I did factory reset but with latest available firmware through the Dashboard. Not sure how to roll back the firmware or even if that is possible.
Same issues with the factory reset using the button on the back of the router.
Netduma-Fraser
Aug 08, 2018NetDuma Partner
