Mike40
Apr 20, 2025Luminary
XR500 BO6 is not in Ping Heatmap
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/XR500-Black-Ops-6-no-ping-on-PC/m-p/2407929 The link above is from the previous discussion with the sameish issue. It was resolved, ...
Netduma-Fraser
May 16, 2025NetDuma Partner
I've checked with the team and every platform is on the same cloud version currently so what you have it outdated - if you resync on Heatmap does it then show an updated list?
Compoza_
May 16, 2025Luminary
no it doesn't show an updated list. As you can see in the picture.
- Netduma-FraserMay 16, 2025NetDuma Partner
Resync the cloud and then get the log from the System Information page please. It's likely the download is being blocked somehow. Is the XR in the DMZ on your ISP modem/router or do you have the ISP modem/router in bridge/modem mode if applicable?
- Compoza_May 17, 2025Luminary
[Time synchronized with NTP server] Saturday, May 17, 2025 22:35:41
[DumaOS] Config Changed: DumaOS_Public_IP, Saturday, May 17, 2025 22:35:44
[DumaOS] Cloudsync Themes result 'false','All mirrors are down', Saturday, May 17, 2025 22:36:01
[DumaOS] Theme path does match manifest 'default', Saturday, May 17, 2025 22:36:01
[DumaOS] The selected theme does not exist: 'default', Saturday, May 17, 2025 22:36:01
[DHCP IP: 192.168.1.101] to MAC address bc:7e:8b:20:75:18, Saturday, May 17, 2025 22:52:47
[DumaOS] DHCP new event., Saturday, May 17, 2025 22:52:47
[DumaOS] DHCP lease change., Saturday, May 17, 2025 22:52:47
[DHCP IP: 192.168.1.101] to MAC address bc:7e:8b:20:75:18, Saturday, May 17, 2025 22:52:48
[DumaOS] DHCP new event., Saturday, May 17, 2025 22:52:48
[DumaOS] DHCP lease change., Saturday, May 17, 2025 22:52:48
[admin login] from source 192.168.1.105, Saturday, May 17, 2025 23:10:17
[admin login] from source 192.168.1.105, Saturday, May 17, 2025 23:10:18
[admin login] from source 192.168.1.105, Saturday, May 17, 2025 23:10:19
[admin login] from source 192.168.1.105, Saturday, May 17, 2025 23:10:20
[admin login] from source 192.168.1.105, Saturday, May 17, 2025 23:10:21
[admin login] from source 192.168.1.105, Saturday, May 17, 2025 23:10:22
[admin login] from source 192.168.1.105, Saturday, May 17, 2025 23:10:23
[admin login] from source 192.168.1.105, Saturday, May 17, 2025 23:10:24
[DumaOS] Ping Heatmap has finished merging data from the cloud!, Saturday, May 17, 2025 23:10:34
[DumaOS] Cloudsync Ping Heatmap result 'true','nil', Saturday, May 17, 2025 23:10:34
[admin login] from source 192.168.1.105, Saturday, May 17, 2025 23:10:45
[admin login] from source 192.168.1.105, Saturday, May 17, 2025 23:10:46
[admin login] from source 192.168.1.105, Saturday, May 17, 2025 23:10:47
[admin login] from source 192.168.1.105, Saturday, May 17, 2025 23:10:48 - Compoza_May 17, 2025Luminary
No bridge mode, XR500 router is connected directly to the FiberLan on the wall
- Netduma-FraserMay 17, 2025NetDuma Partner
It seems to be downloading just fine. If you access in an incognito window the resync and check does an updated list load?
