Xr500
Sep 21, 2018Apprentice
XR500 BUG
Firmware version : V2.3.2.32
QoS -> Traffic Prioritization -> Selector My Pc -> Advanced -> Port Start1 End65535 Protocol TCP&UDP -> DONE
Firmware Previous versions Qos Business ...
- Sep 21, 2018Yes thats the one we're aware of thanks, fixed in the next version
Netduma-Fraser
Sep 21, 2018NetDuma Partner
I can't see the picture but is it an error message? If so we're aware and is fixed for the next firmware.
- Xr500Sep 21, 2018Apprentice
Thank you for your timely response.
Below is the details.
RPC error 'ERROR_UNKNOWN': bad argument #1 to 'len' (string expected, got nil) -> stack traceback: ?: in function <?:73> [C]: in function 'len' ?: in function '?' ?: in function 'decode' ?: in function <?:50> (tail call): ? ?: in function <?:324> [C]: in function 'xpcall' ?: in function 'try' ?: in function <?:290> [C]: in function 'run' ?: in function <?:345> [C]: in function 'xpcall' ?: in function 'try' ?: in function <?:261> (tail call): ? /dumaos/api/cli.lua:48: in function </dumaos/api/cli.lua:30> [C]: in function 'xpcall' /dumaos/api/cli.lua:59: in main chunk [C]: ?
- Netduma-FraserSep 21, 2018NetDuma PartnerYes thats the one we're aware of thanks, fixed in the next version
- ZawolfyOct 01, 2018Aspirant
whens the next firmwawre update?
