Xr500
Sep 21, 2018Apprentice
XR500 BUG
Firmware version : V2.3.2.32
QoS -> Traffic Prioritization -> Selector My Pc -> Advanced -> Port Start1 End65535 Protocol TCP&UDP -> DONE
Firmware Previous versions Qos Business ...
- Sep 21, 2018Yes thats the one we're aware of thanks, fixed in the next version
Netduma-Fraser
Sep 21, 2018NetDuma Partner
I can't see the picture but is it an error message? If so we're aware and is fixed for the next firmware.
Xr500
Thank you for your timely response.
Below is the details.
RPC error 'ERROR_UNKNOWN': bad argument #1 to 'len' (string expected, got nil) -> stack traceback: ?: in function <?:73> [C]: in function 'len' ?: in function '?' ?: in function 'decode' ?: in function <?:50> (tail call): ? ?: in function <?:324> [C]: in function 'xpcall' ?: in function 'try' ?: in function <?:290> [C]: in function 'run' ?: in function <?:345> [C]: in function 'xpcall' ?: in function 'try' ?: in function <?:261> (tail call): ? /dumaos/api/cli.lua:48: in function </dumaos/api/cli.lua:30> [C]: in function 'xpcall' /dumaos/api/cli.lua:59: in main chunk [C]: ?
- Netduma-FraserSep 21, 2018NetDuma PartnerYes thats the one we're aware of thanks, fixed in the next version
- ZawolfyOct 01, 2018Aspirant
whens the next firmwawre update?
- Netduma_JackOct 02, 2018NetDuma Partner
NETGEAR decide when releases occur, which happens after they complete internal testing, so I am afraid we cannot give a timeline.
