JonSnowKnowsNad
Dec 15, 2019Apprentice
XR500 Can someone explain lease obtained and lease expires
Can someone explain lease obtained and lease expires on the dumaOS
Netduma-Fraser
Dec 15, 2019NetDuma Partner
The router provides local IP addresses to devices for a set period of time, in the case of the XR routers it can't be changed and lasts for 24 hours before it expires. The router may give the devices the same address or new ones it depends if there has been any more devices added etc.
JonSnowKnowsNad
What happens when it expires?
- Netduma-FraserDec 15, 2019NetDuma PartnerAfter expiry the router may give the devices the same address or new ones it depends if there has been any more devices added etc. You can give static/reserved IP addresses instead if you want to and then the address will never change.
