WacoJohn's avatar
WacoJohn
Luminary
Nov 10, 2021
XR500 cannot copy (write) to connected external hard drive.
I have two hard drives connected to the router.  They have both worked perfectly in the past.  One is a Western Digital and the other is a Seagate.  They are mapped in W10 Pro to M: And N: respective...
  • Netduma-Fraser's avatar
    Netduma-Fraser
    Nov 11, 2021
    Do you have support with Netgear? If so it would be worth making a ticket with Netgear directly and see what they can suggest
