WacoJohn
Nov 10, 2021Luminary
XR500 cannot copy (write) to connected external hard drive.
I have two hard drives connected to the router. They have both worked perfectly in the past. One is a Western Digital and the other is a Seagate. They are mapped in W10 Pro to M: And N: respective...
- Nov 11, 2021Do you have support with Netgear? If so it would be worth making a ticket with Netgear directly and see what they can suggest
WacoJohn
- WacoJohnNov 10, 2021Luminary
I give up. Can't imbed screen shot. Can't delete a post. Can't delete a reply.
- Netduma-LiamNov 11, 2021NetDuma Partner
When did you start noticing this?
Were there any change to the network recently around the time this issue started?
What firmware version are you currently running?
If you include your screenshot as an attachment to the post, I should be able to see if without waiting for it to be moderated.
- WacoJohnNov 11, 2021Luminary
Netduma-Liam wrote:When did you start noticing this?
1. After Gearhead helped me sort out adding a 2nd HD to the router. The one thing we did not test was writing to them.
2. Not that I know of.
3. 2.3.2.130
By the way ... I think I understand imbedded and attached screen shots as well as reporting posts. Thank you for helping me get that down.
