WacoJohn
Nov 10, 2021Luminary
XR500 cannot copy (write) to connected external hard drive.
I have two hard drives connected to the router. They have both worked perfectly in the past. One is a Western Digital and the other is a Seagate. They are mapped in W10 Pro to M: And N: respective...
- Nov 11, 2021Do you have support with Netgear? If so it would be worth making a ticket with Netgear directly and see what they can suggest
WacoJohn
Nov 12, 2021Luminary
FURRYe38 wrote:I have my XR450 online and will check into this as well.
How are the drives formatter? NTFS? FAT32?
What are the sizes of these drives your using?
NTFS
8 TB
10TB
I've been dinkin around with it.... i deleted the problem drive from Duma and reconnected. No fix though. Thank you for the reply.
Nov 12, 2021Guru - Experienced User
OK, so other that drive size differences, I was able to write to 1st 250Gb USB drive.
Then installed a 2nd 32Gb thumb drive and also write to it.
I use the Share Name path in Map Drive to get Explorer to access the drives:
This is the 250Gb drive installed by itself: Port 1
I placed data on it already prior to installing on the router to see if data would populate.
This is the 32Gb Thumb drive installed WITH the 250Gb USB mechanical drive: Port 2
I formatted the thumb drive for NTFS and left it empty. After installation and map drive. I dragged some files over to the explorer window from the desktop and the files copied over successfully.
Wondering if your situation could be a drive size issue.
Can you try two smaller USB drives as a comparison test to see if the problem continues?
- WacoJohnNov 12, 2021Luminary
Wondering if your situation could be a drive size issue.Can you try two smaller USB drives as a comparison test to see if the problem continues?
Worked fine for several days.
Yes, ... I can but will have to try it tomorrow. THANK you for all your time and assistance.
I will get back to you soon.
- WacoJohnNov 14, 2021Luminary
without whining about how hard it was to trace down the problem, suffice to say the problem drive needed to be formatted. A W10 quick format (restoring device defaults) did the trick. Thank you ALL again for the excellent support.
- FURRYe38Nov 14, 2021Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
