Spoidah
Dec 08, 2019Follower
XR500 can't access settings in chrome
For whatever reason, I'm experiencing the same issues experienced in https://forum.netduma.com/topic/28787-settings-not-appearing/ Basically, using chrome to go to routerlogin.net ends up sometimes ...
Dec 08, 2019Guru - Experienced User
Do FireFox or Opera access these settings?
Clear all browser caches before entering into the routers web page.
- Netduma-FraserDec 10, 2019NetDuma PartnerDo you have any Anti-Virus/Firewall applications at all? We've seen it in the past where this can affect the interface. If so try to add exceptions to them for the interface URL - routerlogin.net* the reason it may not do this when using the IP is it may not recognise it as a website. Also do you have any extensions on the browser? Ad block can sometimes cause the issue as well.
