slink_
Oct 20, 2019Follower
XR500 Can't connect to internet
Having some issues with setting up my new xr500. Old router is working on same setup fine, on a fttp setup it goes through the auto setup when logging in, internet light on router turns white, says I'm connected on all wired/wireless devices in home but doesn't have any actual access to the internet. It asks for pppoe when setting up and have got all of that right since the same thing works on the router currently in use. Any ideas? bit stuck thanks for reading
1 Reply
- Netduma-FraserNetDuma PartnerHello, as you've already got an answer on the Netduma forum regarding your issue would you continue to post there instead so we can keep it in one place? https://forum.netduma.com/topic/29614-xr500-cant-connect-to-internet/
