Jacobpauledward
Mar 31, 2021Follower
xr500 cant get back online after reset
i reset my router as it wasnt filtering for pc games as no servers where showing on the geofilter. i read online that a reset could be useful so i did this, once it reset it started the setup by firs...
dmnial
Apr 01, 2021Aspirant
Hello Jacobpauledward
The power outage may have caused the factory reset due to the sudden nature of turning off. It's not something we can really test for but if it hasn't happening before and only occurred when the power outage occurred I think it should be fine, do keep and eye out though.
Beaker78
May 19, 2021Aspirant
I have this exact same issue, i did not have any power outage, i reset my router and now i cant get past the speed check. Exactally the same issue as OP described.
- Netduma-FraserMay 25, 2021NetDuma PartnerIf you're connecting to the WiFi while completing the wizard and then changing the WiFi details in the wizard you will need to reconnect using the changed WiFi details and you should be able to complete it. Otherwise using ethernet should get you through the wizard without issue.
- IamHappyKMay 28, 2021TutorI got the same problem cant get passen the speedtest. If I full out the Password and security questions then the error 400 pops up and cannot du anything
HELP PLEASE- Netduma-LiamMay 28, 2021NetDuma Partner
Are you seeing this issue across all browser? What about from an incognito window? Do you know what firmware you're currently running?
- IamHappyKMay 28, 2021TutorYes chrome and internet Explorer also in incognito and iam running V2.3.2.120
Iam out of answer's
Thank u
