Adam1712
Mar 03, 2024Aspirant
XR500 Can't Get DumaOS in AP mode
Due to delayed FTTP installation and moving into a garden room, I'm currently using my XR500 in AP mode (I think) but its wired only and I can't enable wireless by the button on the XR500 router. ...
- Mar 03, 2024
For anyone else's benefit in future, it seems like the router (XR500) went into some sort of bridge mode whilst requiring a TFTP firmware update.. I did this and it's all reset and working as it should now in AP mode, internet into WAN port, can access DumaOS via IP address given in BT Hub.
Adam1712
Mar 04, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
