sev7nflow
Dec 19, 2021Apprentice
XR500 can't hard reset, no wifi or access
When I returned from vacation today my XR500 router was not working. I tried connecting to directly the modem and it works fine. I tried hard resetting the router pressing it for over 15 seconds ...
- Dec 20, 2021
Are any lights on?
What color is the power led?
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Netduma-Liam
Dec 20, 2021NetDuma Partner
Sorry to hear this!
If you unplug it from power for a couple of hours to let residual power drain, are you then able to get interface access again once you reconnect it to power?
If not, I'd suggest opening a ticket directly with NETGEAR at support.netgear.com.
