sev7nflow
Dec 19, 2021Apprentice
XR500 can't hard reset, no wifi or access
When I returned from vacation today my XR500 router was not working. I tried connecting to directly the modem and it works fine. I tried hard resetting the router pressing it for over 15 seconds ...
- Dec 20, 2021
Are any lights on?
What color is the power led?
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Dec 20, 2021Guru - Experienced User
Are any lights on?
- sev7nflowDec 20, 2021Apprentice
when i plug it in, the power and ethernet cables when plugged in flash white, but there is no other lights on
to recover via your method, do i need to be able to connect it to a computer? I cannot even hardwire connect to a computer
- plemansDec 20, 2021Guru - Experienced User
Read through the guide and watch the video. It tells you about setting up the pc/laptop with a static ip address and trying to force the firmware to the router.
sweet! this worked! every time i power on/off the router do I need to do this? Or am i set now?
