sev7nflow
Dec 19, 2021Apprentice
XR500 can't hard reset, no wifi or access
When I returned from vacation today my XR500 router was not working. I tried connecting to directly the modem and it works fine. I tried hard resetting the router pressing it for over 15 seconds ...
- Dec 20, 2021
Are any lights on?
What color is the power led?
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
sev7nflow
Dec 20, 2021Apprentice
sweet! this worked! every time i power on/off the router do I need to do this? Or am i set now?
Dec 20, 2021Guru - Experienced User
It should work fine now. Its usually just for recovering when something was corrupted or booting up wrong.
If you mark it solved, it might help the next person
