JaseG
Apr 24, 2022Aspirant
XR500 Can't reach wired nodes from wireless
Hi,
For some reason I can't reach wired nodes from wireless ones (and vice versa) on my network. Router is an XR500.
I'm running a proxmox server on a wired machine which I can reach perfectly fine from other wired nodes, but not from wireless ones. From wireless nodes I can ping the IP address and even use traceroute on the correct port without issue. Whenever I try to reach it in the browser it times out and gives me a socket not connected error. Even trying to ssh to it doesn't work. Both the browser and ssh'ing work from wired nodes, the issue is only from wireless nodes.
On the router I've made an IP reservation for the proxmox server and adjusted the DHCP IP range so it doesn't lease IP's that the proxmox server would use for VMs. My ISP also required the WAN to be setup to run on VLAN 2 - I'm not sure if that would cause any issues. I haven't adjusted anything else to get the internet working on all my devices.
Any help would be greatly appreciated!
Cheers
Jase
- Netduma-FraserNetDuma PartnerMake a guest WiFi network and then enable the option for them to be able to communicate with the local network, connect to that WiFi and then see if it works
- JaseGAspirant
Hi, thanks for the suggestion. I gave that a try and it didn't change the behavior on either the guest or non guest networks.
I also can't connect between devices on the different wireless networks. It's the same deal as between the wired and wireless networks - I can ping / traceroute but can't actually reach anything that I'm hosting.
All IP's are in the same subnet and everything. I must be missing something pretty simple.
- Netduma-LiamNetDuma Partner
What make and model are the wireless nodes exactly?
In Device Manager, are you able to see all devices or are you only able to see the access points?
