JHarper0823
Dec 24, 2019Aspirant
XR500 Centurylink?
I have 1Gig internet from Centurylink and am currently renting a modem through them and I can’t get the range I need in the far corner of the house. So I decided to go with this router to hopefully re...
Netduma-Fraser
Dec 25, 2019NetDuma Partner
If I've understood correctly, you still need to keep your modem in order to have a connection through the router. Routers need either a modem or an ONT to connect to in order to receive internet. There is nothing wrong with this as the modem will just pass all the traffic straight through, just don't connect any devices to the modem and instead have them all connected to the router.
- JHarper0823Dec 25, 2019AspirantNo I don’t necessarily have to keep the modem as I’m renting it for $10 per month and I do have an ONT for the router to connect to. So should that work because it doesn’t seem to be which is why I’m questioning whether it’s compatible or not. I reset the ONT yesterday after reconnecting the Ethernet cable back to the Centurylink modem and that’s when my internet came back on.
- Netduma-FraserDec 26, 2019NetDuma PartnerYes it should work with the ONT, take a look at the modems internet settings if possible, there may be something like a PPPoE login that you will need to enter on the XR500 instead now in order to sustain a connection.
- JHarper0823Dec 31, 2019AspirantI haven’t caught a break to check the settings on the modem but now I saw this model router offered through Costco. Do you feel this would be a better option for what I’m needing? Netgear Nighthawk AX8 8-Stream AX5700 Wi-Fi 6 Router
Thanks so much for your help!
