Kushy58
Mar 05, 2018Apprentice
XR500 compatible with sky fibre
Hi there if I decide to buy the XR500 will it work on sky fibre pro ? Any help appreciated
Kushy58
Hi there, so I won’t need to buy a modem then as the sky Q router will act as it.
Netduma-Fraser
Mar 05, 2018NetDuma Partner
Yes that's right, I'm unsure if they allow you to do away with the hub completely but for all intents and purposes you only need the router.
- Kushy58Mar 05, 2018Apprentice
I did actually ask them and got the in terms and conditions they don’t allow other routers. So by turning it into a modem I’m still technically keeping it lol. Well I shall order the XR500 in ten days once my line has gone through their testing phase to get my best line speed it is supposed to be minimum of 68Mpbs max of 80Mpbs download and upload of 20Mpbs
- Netduma-FraserMar 05, 2018NetDuma PartnerHaha definitely! Great to hear you'll be purchasing the XR500, we're sure you'll love it. If you have any further questions between now and then or after we'll be happy to help!
